Boeing 737 MAX
Păi na, motoarele respective au modificat mult profilul aerodinamic. Mă rog, de acolo au început problemele.
Ha ! Cata generozitate ! Mi se pare aproape nesimtire:
Sunt sigur ca procesele ii vor ajuta sa scoata mult mai mult decat si-au propus.
Europe’s aviation regulator has outlined five major requirements it wants Boeing Co. to address before it will allow the planemaker’s 737 Max to return to service ...EASA’s checklist includes a number of issues that have been disclosed: the potential difficulty pilots have in turning the jet’s manual trim wheel, the unreliability of the Max’s angle of attack sensors, inadequate training procedures, and a software issue flagged just last week by the FAA pertaining to a lagging microprocessor. But the agency also listed a previously unreported concern: the autopilot failing to disengage in certain emergencies.
bloomberg.com
AM
Si atunci se pune problema ce puiii mei facea FAA cand certifica Maxul; jucau solitaire in acelasi timp si nu au fost foarte atenti ca avionul nu prea zbura? Sau zbura in hopuri?
transporter
FAA din lipsa de personal a delegat o parte din munca de certificare catre ... Boeing. Iar Boeing sunt in primul rand interesati de banii pe care trebuie sa ii scoata pentru actionari.
Ha ! Se pare ca Boeing (sau doar Ryanair) va renunta la particula MAX din denumire.
Cu siguranta astfel va deveni astfel un avion mult mai sigur .Nu vreau sa supar dar astfel de cosmetizari imi amintesc de "tigan"transformat in "rom".
Ca parere personala, eu nu stiu daca se va ajunge la o solutie satisfacatoare de soft care sa compenseze problema mecanica a pozitionarii motoarelor ,plus rezolvarea celorlate probleme descoperite dupa si ,nu m-as mira sa se revina la 738 pana la lansarea unui produs facut de la zero.
A select group of US and international airline pilots are expected to participate in the final round of simulator testing of Boeing's new flight control system software for the 737 MAX as soon as early November, according to two sources familiar with the plans.
This timeline, which has not been previously reported, is a sign Boeing engineers' months long work to fix the plane's flight control software is nearing completion...
The FAA will observe how pilots interface with the planes' new flight control software, and those observations will dictate the sort of pilot training the FAA will propose, the source said...
A Boeing source believes if all goes according to plan the FAA will unground the plane by the end of the year and airlines will begin flying it by early 2020.
flight.user
Mi se pare inadmisibil ca in ziua de azi cand dupa atatea decenii de experienta castigate in domeniul sigurantei, a proiectarii si instructajului, cu buna stiinta sa ignori un element crucial de siguranta care in final a dus la atatea decese.
Cel mai mult de suferit au in aceste momente familiile celor ucisi cu buna stiinta de cei de la Boeing si companiile care isi asteapta comenzile si le dau toate planurile peste cap.
Pt Boeing in schimb nu mi pare rau deloc, sa stea cu avioanele prin parcarile supermarketurilor si sa i usture cat mai tare financiar. Nu este posibil ca in ziua de azi sa se intample astfel de accidente! Poate e cazul sa proiectez si un nou avion, nu sa tot incerci sa l imbunatatit pe unul din anii ‘60!
transporter
Productia de 737 a fost suspendata ca urmare a incertitudinii privind ridicarea interdictiei de zbor.
O sa fie o piatra de moara serioasa pt Boeing toata situatia asta cu 737. Trebuie sa plateasca despagubiri semnificative catre companiile aeriene care au MAX comandat, pe langa lipsa cash flow-ului din vanzarile de 737. Cel mai probabil aceasta suspendare va dura minim 3 luni dar posibil chiar si 6 luni. S-ar putea sa vedem multi furnizori in faliment ceea ce ar putea afecta si Airbus intr-o oarecare masura.
Oare este de bine ?
This airplane is designed by clowns, who in turn are supervised by monkeys," a company pilot said about the Boeing 737 Max in a message to a coworker in 2016.
Banuiesc ca pilotul era incantat ca MAX este un avion care te binedispune ,prietenos cu natura.
I'll be shocked if the FAA passes this turd," an employee said of the Boeing 737 Max in a May 2018 message.
"Would you put your family on a MAX simulator trained aircraft? I wouldn't," one employee messaged another in February 2018.
Si se pare ca si noul 777 are vitorul la fel de stralucit:
"Best part is we are re-starting this whole thing with the 777X with the same supplier and have signed up to an even more aggressive schedule!" an employee said expressing concern about picking the lowest cost simulator supplier.
"I don't know how to fix these things…it's systemic. It's culture. It's the fact that we have a senior leadership team that understand very little about the business and yet are driving us to certain objectives," an employee wrote in June of 2018.
Citatele sunt din https://www.investors.com/news/beoing-737-max-shocking-internal-messages/
transporter
Mai putem vorbi de ghinioane ? Sau e vorba de ceva sistemic la Boeing ? Eu as zice ca mailurile angajatilor care reclamau tot felul de probleme (care au fost ignorate) si plata dividendelor catre actionari cu prioritate fata de orice alte cheltuieli ne indica ca de fapt la Boeing prioritatile sunt un pic date peste cap de cativa ani. Acum doar culeg ce au semanat in anii astia cu Muilenberg in frunte.
Din articolul citat de @etravel :
Foreign object debris, an industrial term for rags, tools, metal shavings and other materials left behind by workers during the production process...
:eek:
At a Congressional hearing about the Max crashes last December former Boeing executive Ed Pierson described conditions at the company’s Renton, Washington facility as “chaotic” and said he had reported “serious concerns about production quality” to management, warnings that were ignored.
