Incepand cu 27 ianuarie 2019, TAP Air Portugal a decis suspendarea operarii pe ruta Lisabona – Bucuresti. Referitor la biletele emise pentru zboruri dupa data de 27 ianuarie 2019 si rezervarile de grupuri, compania va reveni cu instructiuni.
Este pentru a doua oara cand TAP anunta ca se retrage din Romania. De aceasta data, retragerea pare sa fie definitiva. Motivul: profitabilitate scazuta pe acesta ruta. Pasagerii care au rezervate bilete dupa 27.01 vor fi rerutati pe alte companii aeriene sau le va fi returnata contravaloarea biletului, daca doresc sa-si anuleze zborul. Acum, doar Blue Air mai zboara intre OTP si LIS, iar Wizz Air va relua zborurile pe aceasta ruta in aprilie 2019.
‘TAP informs that, as of January 27, it will no longer operate the Lisbon-Bucharest route. Clients with flights already scheduled for after January 27th will be protected on flights from other airlines, will be informed accordingly and may also be reimbursed, if they wish to cancel their flights.
TAP regrets the discontinuation of this route. This was the second attempt to operate in this market. This line was resumed, however, it was again verified that the low profitability does not justify its continuity.’
Continue reading...
Continue reading...
